reinstall of Geopsy
Posted: Thu Jun 11, 2020 10:43 am
by Michael Ezersky
How I can reinstall Geopsy new version to do not damage the old version
Re: reinstall of Geopsy
Posted: Mon Jun 15, 2020 8:18 am
Install it in a different path. Expect some minor problems when running two incompatible version:
- The same configuration is shared by all versions, hence there can be some minor problems.
- Geopsy tools are plugins. Each time you switch from one version to the other, make sure that you change the path to the plugins (under "File/Preferences", "Tools" tab). To avoid any crash, before leaving a version, remove all tools. Start the new version, add all tools from the correct path and restart geopsy.
