ERROR INSTALLATION IN UBUNTU 20.04
chasananda
Post by chasananda »
Hello Marc,
I was trying to install geopsy software, but when I ran
sudo make install
the following error occured:
cd mseed/ && ( test -e Makefile || /usr/lib/qt5/bin/qmake -o Makefile /opt/geopsy-3.3.0/mseed/mseed.pro ) && make -f Makefile install
make[1]: Entering directory '/opt/geopsy-3.3.0/mseed'
[ -d /opt/geopsy-3.3.0/lib ] || mkdir -p /opt/geopsy-3.3.0/lib
cp /opt/geopsy-3.3.0/lib/libmseed.a /opt/geopsy-3.3.0/lib
cp: '/opt/geopsy-3.3.0/lib/libmseed.a' and '/opt/geopsy-3.3.0/lib/libmseed.a' are the same file
make[1]: *** [Makefile:30: install] Error 1
make[1]: Leaving directory '/opt/geopsy-3.3.0/mseed'
Geopsy .v3.3.0
QMake version 3.1
Using Qt version 5.12.8 in /usr/lib/x86_64-linux-gnu
gcc (Ubuntu 9.3.0-10ubuntu2) 9.3.0
Could you please help me to fix those problems?
Re: ERROR INSTALLATION IN UBUNTU 20.04
Can you try with 3.3.2 or even better from the git repository with 3.3.3-preview?
See download page to access the git repository.
chasananda
I tried Geopsy 3.3.2 then I got the same problem.
cd mseed/ && ( test -e Makefile || /opt/Qt/5.15.0/gcc_64/bin/qmake -o Makefile /opt/geopsy-3.3.2/mseed/mseed.pro ) && make -f Makefile install
make[1]: Entering directory '/opt/geopsy-3.3.2/mseed'
[ -d /opt/geopsy-3.3.2/lib ] || mkdir -p /opt/geopsy-3.3.2/lib
cp /opt/geopsy-3.3.2/lib/libmseed.a /opt/geopsy-3.3.2/lib
cp: '/opt/geopsy-3.3.2/lib/libmseed.a' and '/opt/geopsy-3.3.2/lib/libmseed.a' are the same file
make[1]: Leaving directory '/opt/geopsy-3.3.2/mseed'
make: *** [Makefile:152: sub-mseed-install_subtargets-ordered] Error 2
I haven't try Geopsy 3.3.3-preview but I will try it. I really don't have a clue with this problem. Is it from the os that I used or maybe from the Qt? Could you please give me any suggestions?
Thank you.
Nanda
chasananda
In file included from ../../QGpCoreTools/src/XMLClass.h:35,
                 from ../../QGpCoreTools/src/ColumnTextDescription.h:32,
                 from ../../QGpCoreTools/src/QGpCoreTools.h:19,
                 from ../../gpcurve/src/CurveReader.cpp:27:
../../QGpCoreTools/src/XMLMember.h:77:13: note: because ‘QGpCoreTools::XMLMember’ has user-provided ‘void QGpCoreTools::XMLMember::operator=(const QGpCoreTools::XMLMember&)’
   77 | inline void XMLMember::operator=(const XMLMember& o)
make[1]: *** [Makefile:1142: CurveReader.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/opt/geopsypack/geopsy-src/gpcurve'
make: *** [Makefile:2837: sub-gpcurve-make_first-ordered] Error 2
make: Leaving directory '/opt/geopsypack/geopsy-src'
when I ran
make -j 8 -C /path/where/you/want/to/build
I'm sorry about this issue because I installed Geopsy 3.4, so this question isn't relevant anymore.
chasananda
Finally I installed Geopsy 3.3 from the git repository with Qt 5.15.0.
Hi Nanda,
Good to read that you finally found a solution. Any particular error you fixed with Qt 5.15? I've never tried it, I'm still with Qt 5.14. If you still have the 3.4 folder available, I would be curious to get the full log (re-run make in it). The ending part you provided does not contain all the information needed to localize the error.
I'll check the former errors you got with 3.3.2. I think that a "make -i" would have provided a working package because the reported error is minor.
