parametrization space by command lines
Hcadet
Postby Hcadet » Mon Nov 16, 2009 10:11 am
Is there any way to create a parametrization space (I mean a toto.param file) by command line (without the dinver interface)?
(and without using gpdepths that is a specific parametrization)
Thanks!
Bye
Heloise
Postby admin » Fri Nov 27, 2009 2:23 pm
You can generate your own xml content at your own risk. Nearly all "geopsy" formats are compressed xml files. At input, the xml can be compressed (inside a tar structure) or not (plain text).
To have an idea of the xml structure of a .param file:
tar xvfpz toto.param
If toto.param was previously generated by Dinver or gpdepth. This will produce a contents.xml file encoded in UTF-16 (no ASCII). See http://www.geopsy.org/forum/viewtopic.p ... ight=iconv for more details.
Once edited, you can rename your file to .param:
mv contents.xml toto.param
Return to “Dinver usage”
