gcc compatibility
Place here all posts related to implementation and source codes. This forum is rather technical and reserved for programmers.
valerio
gcc compatibility
Postby valerio » Sun Oct 25, 2009 10:20 am
just an idea: the header qtbwave.h can be modified the following way, to get compatibility with gcc using pure C calls.
Additionally: do you also have a C wrapper for ellipticity calculation?
I'm asking only because I don't want to reinvent the wheel ( :D ), otherwise I'll try to add it my self (hope I'll be able!)
Ciao and thanks.
# ifndef QTBWAVE_H
# define QTBWAVE_H
#ifdef __cplusplus
extern "C" {
#endif
void dispersion_curve_init_();
void dispersion_curve_rayleigh_( int * nLayers, double * h, double * vp, double * vs, double * rho,
int * nSamples, double * omega,
int * nModes, double * slowness );
void dispersion_curve_love_( int * nLayers, double * h, double * vp, double * vs, double * rho,
#ifdef __cplusplus
#endif
# endif // QTBWAVE_H
valerio
Postby valerio » Mon Oct 26, 2009 8:20 am
I propose the following modification for qtbwave.cpp and qtbwave.h, to include ellipticity calculation (and peak may be, see attachment).
Regarding the calculation of ellipticity peaks, I notice that with some complex models and setting the precision (dispersion.setPrecision( 1e-15 );) the program crash. Is that because the function is experimental or I'm doing something wrong? :-)
Ciao and thanks
qtbwave.h
(907 Bytes) Downloaded 320 times
qtbwave.c
(4.77 KiB) Downloaded 301 times
Return to “Developer's corner”
