reinstall of Geopsy
Michael Ezersky
reinstall of Geopsy
Post by Michael Ezersky »
How I can reinstall Geopsy new version to do not damage the old version
Re: reinstall of Geopsy
Install it in a different path. Expect some minor problems when running two incompatible version:
  1. The same configuration is shared by all versions, hence there can be some minor problems.
  2. Geopsy tools are plugins. Each time you switch from one version to the other, make sure that you change the path to the plugins (under "File/Preferences", "Tools" tab). To avoid any crash, before leaving a version, remove all tools. Start the new version, add all tools from the correct path and restart geopsy.
