Dinver dispersion and ground profile plots
Posted: Thu Oct 27, 2011 12:31 am
by Theodora
I am new user of dinver and started with the theoretical exercise supplied in the manual. Although forward modelling gave results as expected following inversion procedures significantly differ from those in the manual. First, run inversion menu is not the same as in the manual. Second, using standard parameters the results seems to be wrong and resulting graphs as well (picture attached). Could you clarify, please, what is the problem here.
Thank you very much,
Theodora
Re: Dinver dispersion and ground profile plots
Posted: Thu Oct 27, 2011 2:45 pm
From the table listing the inversion runs, I suspect that you are using the development release. I suggest you to start with the stable or testing release which will certainly give you the same menus and the same results as in the tutorial
Posted: Fri Oct 28, 2011 1:21 am
by Theodora
I download the geopsy.org package, release2.4.2, src, from download page. Is that the stable or the development release? And if it is development, where can I find the stable src?
thanks,
Theodora
Posted: Wed Nov 09, 2011 2:47 pm
No 2.4.2 is the stable release
If you are running under Linux, you can run: dinver -version
To make sure that you are running the correct version. If unsure, you can post the result here.
Posted: Mon Nov 14, 2011 2:17 am
by Theodora
Thank you! Version of the linux source available from download area is
$ /opt/local/contrib/bin/dinver -version
Versions:
Qt 4.6.2
QGpCoreTools 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
(built on 201109231614)
DinverCore 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
QGpGuiTools 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
DinverGui 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
SciFigs 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
dinver 0.0.0-snapshot-20110923 from geopsypack-0.0.0-snapshot-20110923
It seems that its not stable version. From where can I download the stable source?
Thank you, Theodora
Posted: Mon Nov 14, 2011 8:41 am
This is effectively the snapshot-development release.
Use of that release is reserved to expert users or those who want to test new features.
The stable/testing release is available here or by default when you click on "download".
http://www.geopsy.org/download.php?plat ... ch=testing
