max2curve
Posted: Wed Dec 07, 2011 12:30 am
by Theodora
I wanted to use max2curve from the f-k conventional too in geopsy, but when I tried to load the already existing *.max file it says "no max result can be loaded". Any idea what may cause that?
thanks, Theodora
Re: max2curve
Posted: Thu Dec 08, 2011 11:03 am
Can you post the first lines of your .max file?
Basically, I would need the first lines starting with "#" and a few data lines just after the last "#".
You get this message because max2curve cannot identify the type of results to analyze (FK, SPAC, plain curve, HVTFA), probably a missing header or an old one.
Re: max2curve
Posted: Fri Jan 06, 2012 6:04 am
by Theodora
sorry for late reply. It is output of conventional F-K toolbox that I can not visualize with max2curve. Surprisingly, results of F-K for passive experiments can be visualized.
Re: max2curve
Posted: Wed Jan 18, 2012 4:30 pm
Your max2curve file is empty. There is nothing else than the header (starting with #)
Check your processing parameters in Geopsy.
