Combining MASW & ReMi with a linear array
Posted: Fri Dec 23, 2011 7:15 pm
we are doing a lot of active and passive measurements using a linear array of 5m spaced geophones (12 channel array).
After computing dispersions curves using geopsy and seg2curve softwares, we obtain systematically a vertical gap between both curves. ReMi's dispersion curve shows always larger phase velocities.Is that matter directionality of ambient noise ??? Can you suggest me a procedure to combine both dispersion curves ?? Perhaps a phase velocity shift of the ReMi dispersion curve ??
Thank very much
PS: mery christhmas !!
Thank very much
