gptarget to extract dispersion curve from a file.target
Posted: Fri Jul 06, 2012 3:57 am
When I used the command line to run the codes as following:
to extract the dispersion curve of fundamental Rayleigh from the below two files,
a message "gptarget: curve index out of bounds (-1)" is shown.
What's the problem? And I use the Geopsy.org packages, release 2.4.4, win32.
Waiting for your response. Thank you very much!
gptarget E -disp 0 Lep_ring01_3C.target
gptarget E -disp 0 Lep_ring01_3C_dinver.target
