HVSR frequency band
Posted: Thu Feb 04, 2021 12:58 am
I run HVSR on data and filter it for example up to 25 Hz (under the time windows tab). Then I set frequency sampling to 0.5-125 Hz under the output tab. in the HVSR plot, I can still see peaks around 100 Hz, despite filtering signals up to 25 Hz. I am wondering what is the reason for that? does the HVSR plot show the results from the filtered signal or the raw one? (please see the figure attached)
Laleh
Laleh
