a new plug in in the 3.4 version
Posted: Tue May 04, 2021 1:11 pm
by luigiV
in the version of Geopsy 3.4 there is a new plug in: Phase lt, but no information on its meaning and use.
Would it be possible to have a brief explanation of the new tool?
trying this version i verified that spac2disp doesn't work.
Re: a new plug in in the 3.4 version
Posted: Thu May 06, 2021 7:36 am
PhaseIt is a tool for comparing signals of Huddle Tests (all sensor at the same place, max 1-2 m), below some frequency the response of all sensors should be the same. This tools computes the coherence, the phase shifts and the spectral ratios versus time and frequency. I hope to submit a short paper on it soon.
Can you detail what's wrong with spac2disp? I checked quickly with vertical data and I noticed no problem. It works also with 3C data.
Posted: Thu May 06, 2021 9:08 am
by luigiV
it just doesn't start. When in geopsyland I type spac2disp nothing happens and the same happens if I click directly from outside of geopsyland on spac2disp.
I also tried the new Frequency Rejection utility. I also read the paper and I noticed that the parameter n (or v) is crucial to significantly modify the morphology of the HV curve. I am attaching three pics where the raw HV curve (geometric mean) is represented and the result of the Frequency Rejection with SD 2 and 1.5 where the peak at 0.6Hz gains in amplitude exceeding the value 2 and satisfy the SESAME criterions for natural HV peak.
Which criterion should be used for this parameter? Can the result I obtained with SD1.5 be considered correct?
And finally, when is it preferable to adopt the geometric average rather than the squared average?
Posted: Thu May 06, 2021 12:28 pm
spac2disp is now fixed in 3.4.2-preview (git repo).
The geometric average suggests that the E and N are two quantities that are better represented on a log scale. However, I see E and N as two components of a vectorial field, hence the combination through "Total horizontal energy" sounds better. The "Square average" is the same with a factor sqrt(2). I would say that for historical reasons the last one is mainly used.
I also noticed that a factor 2 is not removing many time windows. 1.5 is more effective. Is it better? The uncertainty is reduced but is it more accurate? I have no answer.
Posted: Thu May 06, 2021 2:42 pm
by luigiV
so this approach to window selection is interesting, but not conclusive.
Finally I found that gphistogram opens the max files of HVTFA, but it represents them in an incomprehensible way. I am attaching a picture.
Posted: Thu May 06, 2021 4:09 pm
Yes, there is still some work to really read those .max files into gphistogram.
