Export image as *.svg doesn't work
Posted: Mon Apr 25, 2022 4:30 pm
by javiermt
I want to export image from H/V module as svg format, but doesn't work. Image is out on frame. I don't understand why happens.
Before export image, I changed object properties (width 9 cm and height 9 cm). I'm using geopsypack-52items-win64-0.0.0-snapshot-20170109.
Javier M.
Re: Export image as *.svg doesn't work
Posted: Mon May 02, 2022 10:12 am
Hi Javier,
Thanks for pointing out this bug. I have effectively the same result for any .svg export.
I will try to fix it for the next release.
Posted: Mon May 02, 2022 12:19 pm
The view box was not set correctly when exporting to SVG. This is fixed for 3.5.0.
With Inkscape, the SVG file is viewed correctly even if the bounding box is not properly defined.
Thanks again for your report.
