GeoPsy crashes when attempting to save results
alexkover
Post by alexkover »
Hi
I'm relatively new to HV and GeoPsy so bear with me if I don't know how to do things quite right yet.
I've been running into problems with GeioPsy crashing when trying to save the results from the H/V tool. Plus I can't report the crash from the crash window that pops up because it says that I'm using an old release despite having the current version.
After using the H/V tool to generate an H/V curve, I wanted to save the data from it. In the H/V Results window, under the Tools dropdown menu, I selected Save Results. After selecting a location to save the .hv file, GeoPsy crashes. This happens every time I try to save the data.
I've attached the crash report in a .txt.
Is there a better way for me to save the H/V data than my current process?
Alex
Crash Report when Trying to Save HV Results.txt
(4.86 KiB) Downloaded 2174 times
Re: GeoPsy crashes when attempting to save results
From the crash report, I can read that you were using version 3.3.1. This problem is fixed in 3.3.2 available from download page.
To export results, you may also use geopsy-hv from a terminal. See" -h all" for the details of the available options. Or search ths forum and the wiki, there are other posts related to this tool.
alexkover
Post by alexkover »
Thanks for the feedback,
I downloaded the newest version and tried again, but Geopsy still crashed. I'll continue looking into more options for exporting data.
Attached is the crash report.
Crash Report when Trying to Save HV Results v3.3.2.txt
(4.86 KiB) Downloaded 1967 times
I tried today to save the H/V results with 3.3.2, but the program crash.
I don't know why. It happens with all releases with Geopsyland.
I think I'll forced to come back to snapshot 0.0.0. a more stable release.
Effectively, this not fixed in 3.3.2 but for 3.3.3
It will be available soon.
