Spac 3C
Spac 3C
I processed a 9 stations, 3 components, 2D array with Spac.
When I open the target file with Spac2disp it warns me that there are 3 curves per ring and therefore I have to use Dinver to choose a curve per ring and then export the target file with File / Export Target.
I select the radial curves and then try to export with File / Export target, but unfortunately the program crashes.
Is this a bug or did I do something wrong with the procedure?
Re: Spac 3C
If it crashes, it is definitively a bug. Can you send me the bug report? And eventually the file that produced the crash.
If you process a 3C dataset with SPAC, you have to post-process with option '-VRT' in spac2disp.
Re: Spac 3C
I am attaching the target file generated by Spac 3c.
I don't understand the meaning of the VRT option in post process with Spac2disp because spac2disp doesn't open reminding me that there are 3 curves per ring and that I have to choose one with Dinver.
Bug Dinver file export report:
<CrashReport>
<Error>
<message>Segmentation fault Signal</message>
<time>2021-12-16 10:59:23.601</time>
<threads>main,layerPainter1,layerPainter2,layerPainter3,layerPainter4,layerPainter5,layerPainter6,layerPainter7,layerPainter8</threads>
<currentThread>main thread</currentThread>
<stack>---- thread main
QGpCoreWave::ModalStorage** QGpCoreWave::AutocorrFactory::newHorizontalStorage():158
void QGpCoreWave::AutocorrFactory::init():193
void DinverDCCore::TargetList::validateTargets():169
DinverDCCore::TargetList* TargetListWidget::targetList():390
virtual void DCPlugin::xml_writeChildren(QGpCoreTools::XMLStream&amp;, QGpCoreTools::XMLContext*) const:213
virtual void DinverCore::XMLDinver::xml_writeChildren(QGpCoreTools::XMLStream&amp;, QGpCoreTools::XMLContext*) const:69
void QGpCoreTools::XMLClass::xml_save(QGpCoreTools::XMLStream&amp;, QGpCoreTools::XMLContext*, const QGpCoreTools::XMLSaveAttributes&amp;) const:306
---- thread layerPainter1
virtual void SciFigs::LayerPainterThread::run():59
---- thread layerPainter2
---- thread layerPainter3
---- thread layerPainter4
---- thread layerPainter5
---- thread layerPainter6
---- thread layerPainter7
---- thread layerPainter8
</stack>
<bugStack>---- thread main
---- thread main
</bugStack>
</Error>
<application>dinver</application>
<version> Qt 5.12.3
QGpCoreTools 2.4.2 from 3.4.2
(commit 33d7a93616e30a3d511fa67ad3f5da9da1a4aac6)
QGpCoreMath 1.4.2 from 3.4.2
(commit 306e3c199829ace6cbde6b242503355428580d05)
DinverCore 1.3.1 from 3.4.2
(commit 7a17c1522ca1f626c89f2c1e87759f6b4a9311d4)
QGpGuiTools 2.4.2 from 3.4.2
(commit 478ff49d6d6ec28d92b21ec9bfcef9f5d343b065)
SciFigs 3.3.2 from 3.4.2
(commit cec1d051784e8ee1d9774230fb96c1bb0b618aa0)
dinver 1.1.3 from 3.4.2
(commit 274c3fc3e960b5cbf312a1fb633dfa145cfb87e8)
GeopsyCore 4.4.2 from 3.4.2
(commit 583bacf54d7367d6c29796a28c8179b98d88e28a)
geopsyfigs 1.0.2 from 3.4.2
(commit 33697385e465d0d0ec4344aba55058811e934918)
QGpCoreWave 2.2.0 from 3.4.2
(commit 18e08f9fd358a9e504047ec288ca4ab71a7c9851)
QGpCompatibility 1.1.2 from 3.4.2
(commit 3e05f6333687b574d4a18fb4336decd9efbe3efa)
DinverDCCore 2.2.0 from 3.4.2
(commit 654cab13b392853128bb5fa90891ecf10b5c3f0c)
QGpGuiMath 1.3.1 from 3.4.2
(commit 8e80e068f4f3b16a30e8fb8dff21177f25a58da6)
QGpGuiWave 1.2.1 from 3.4.2
(commit 2889d6a23de9671c33c0ae088b33e537035df26f)
DinverDCGui 1.2.1 from 3.4.2
(commit 5ec61aa367b7463b3d580053b5e649d9e77275a4)
DinverGui 1.0.0 from 3.4.2
(commit 99543a6c08a0428e3083a9d983dcc9da71a1b069)
dinverdc 2.1.1 from 3.4.2
(commit da8a302ad46dca29bdb46d9d539405c63dd5c1f5)
dinverext 1.0.5 from 3.4.2
(commit d4b69063b6a408e6cc7e437d39fcc5c0be3c5bda)
dinvermatlab 1.0.3 from 3.4.2
(commit ec29d122be365b7639f75cd16c4416daa17e8c51)
</version>
<system>windows 10</system>
</CrashReport>
spac_sara.target
(41.6 KiB) Downloaded 1872 times
(96.16 KiB) Not downloaded yet
