First of all, thanks to you Marc for your effort developing and maintaining Geopsy.org, it's very useful.
I wonder how can I save in a text file the picks of first breaks in the signal general view.
Emiro Chica
First break pick general view
Re: First break pick general view
Hi Emiro,
One way to export time picks is to select format "Arrival times" when using menu "File/Export". It export all signals from the current active viewer.
Another way to move all signals to export in a table viewer. With menu "View/Set data fields", set the list of columns you want to export. Use menu "File/Export" and file format "Table" (available only if the current viewer is a table).
Sorry, I just saw your answer, thank you very much for your support.
Emiro
Emiro
