error install Geopsy
ESBornand
Post by ESBornand »
Dear, I have tried to install the latest version of GEOPSY, when I opened the software I got the error that I attached in the image, what could it be?
Regards.
(15.41 KiB) Not downloaded yet
Re: error install Geopsy
I've never read this error message. I guess that you get the same message for all the other graphical applications.
Did you run 3.5.2? What is your Windows environment? I suppose it is still Windows 10. I compiled and tested this release under Windows 10 without getting this error. Did you try with past geopsy releases (3.4.2 or older)?
If you can find no way to solve this issue, you can try to install it under a Linux OS that you can run in a virtual machine (Virtual Box for instance or other virtualization solutions).
I'm not a Windows expert, everything related to geopsy is developed under Linux. Maybe other users under Windows experienced the same issue and found a solution. To make your post more "searchable", I would suggest you to type the text of the error message in your post rather than a screen shot. You can always modify your past posts by clicking on the pencil icon.
