I hope this message finds you well. I am writing to seek your assistance with an issue I encountered while conducting inversion tests using the command line.
I initiated the inversion using the following command:
dinver -i DispersionCurve -optimization -target /Test/Data/t.target -param /Test/Data/p.param -o /Test/Data/r.report
Subsequently, I used the gpdcreport command to review the inversion results. The basic output command worked as expected:
However, when I attempted to use the command with additional arguments, specifically:
gpdcreport /Test/Data/r.report -aV 0
The output did not display the expected results and instead, I received only the following output:
I found that using gpviewdcreport allows me to view the results correctly. Attached, you will find the relevant process and result files for your review.
Google Drive:
https://drive.google.com/drive/folders/ ... sp=sharing
Lijiong
