Hi guys,
I'm an italian user of geopsy.
I work with the vibration monitor of ABEM, the product name is vibraloc.
It saves files in *.vibraloc format but they can be export in a particular ascii format.
This format can be easely trnsform into a file readable by geopsy but it takes a lot of time. I'd like o know if there's any chances to implement, in the next release, the possibility to read this format.
I attached a file to example.
It is similar to the *.saf files in the type of data. There is 4 channels because vibraloc has the possibility to implement a microphone during the acquisition (channel 4), but that channel can be exclude for the use with geopsy.
Many thanks, Fabio.
ABEM Vibraloc Ascii files
- 0493_0297_0701191435.txt
- (646.42 KiB) Downloaded 2616 times
Probably a late answer, just for information. The latest release can parse any kind of ascii file (>=20091214). You just have to specify how to retrieve the information from the header. A knowledge of Regular Expression is required to build the file parser. There are plenty of tutorials on the web.
The tool for designing a new file parser is still in a very early stage. Automatic refresh of the file example is still not working properly (happen only after a 'load').
To access the file parser designing tool, turn the load format to 'Ask for file format' in preferences, import a text file and select multi-column ascii format.
