no rings for spac
lesage
no rings for spac
Post by lesage »
I am using SPAC.
First, I defined 5 rings but only the first 3 rings were taken into account during the first run. Then I removed these 3 rings and keep the remaining 2 rings for a new run. When I started the SPAC, I obtained the following message: You forgot to define the rings
I tried to define in several manners the new rings but it never worked.
Version 2.6.3(sesarray-2.0.5)
Philippe
Hi Philippe,
Can you post you .ring file? (containing 5 and 2 rings for instance)
lesage
rings
Post by lesage »
Today, Geopsy did not send warning and could run. But it processed only the first 3 rings. I send you 2 .ring files and the last log file.
Philippe
