gpprofile: mean profile
Hcadet
Post by Hcadet »
Using gpprofile it is possible to compute a mean profile from a report file (right?), with a carefully choose file.report.
I would like to know how is it possible to also compute the standard deviation?
regards,
Heloise
Hi Heloise,
To produce ground models out of a report, with a misfit less or equal to 1:
gpdcreport my_run.report -gm -m 1
Then, you can chain this output to gpprofile to extract Vs profiles, for instance:
gpdcreport my_run.report -gm -m 1 | gprofile -vs
This output a 'ready to plot' curve. For statistic computation, this is not exactly what we want. Instead, I suggest to re-sample the profile, let's say every 1 meter down to 50 meters:
gpdcreport my_run.report -gm -m 1 | gprofile -vs -resample -d 50 -n 50
Next we compute the statistics over this ensemble of profiles.
gpdcreport my_run.report -gm -m 1 | gprofile -vs -resample -d 50 -n 50 | grep -v "#" | awk '{print $2,$1}' | gphistogram -y-min 150 -y-max 3500 -x-min 1 -x-max 50 -x-count 50
The grep and awk are mandatory to remove comment lines and to swap first and second columns. gphistogram constructs one histogram per x bin. Hence, if not swapping, you'll obtain one histogram for each velocity rather than for each depth.
Finally, you can extract the mean, median, mode,.. with its deviation thanks to option '-mean', '-median',...
gpdcreport my_run.report -gm -m 1 | gprofile -vs -resample -d 50 -n 50 | grep -v "#" | awk '{print $2,$1}' | gphistogram -y-min 150 -y-max 3500 -x-min 1 -x-max 50 -x-count 50 -mean
With latest snapshots (<200907), you will get all value twice out of gpprofile -resample. The next snapshot will be soon available. Meanwhile you can filter out this double values, for instance with the following script:
gpdcreport my_run.report -gm -m 1 | gprofile -vs -resample -d 50 -n 50 | grep -v "#" | awk 'BEGIN{d=-1}{if($2!=d){print $2,$1;d=$2}' | gphistogram -y-min 150 -y-max 3500 -x-min 1 -x-max 50 -x-count 50 -mean
Hcadet
Post by Hcadet »
Hey Marc!
Thanks a lot!
Heloise
fpinto
Re: gpprofile: mean profile
Post by fpinto »
Hy Marc,
I am a new user with Dinver and I have been trying to get the mean profile of my inversion.
I have followed the command lines that you indicate here, but i can't use the grep and awk.
I am using Ms-dos and the code works just fine until this part:
Should i use another command line instead of Ms-dos? Is Matlab a better one? Or is it a code problem?
Thank you for your time.
Francisco
