geopsy command line usage under new version
bre
Post by bre »
I tried to run geopsy high-resolution FK from the command line, like always worked before, with a new version of geopsy
(GeopsyCore 3.3.0-snapshot-20101119 from geopsypack-2.1.0-snapshot-20101119 (built on 201011191741)
geopsy 2.7.0-snapshot-20101119 from geopsypack-2.1.0-snapshot-20101119 (built on 201011191741)).
Now, when using the command
geopsy -db /data2/NORSAR/noise/sac/Summer96.gpy -group doy153 -tool geopsyarray -slot 1 -param HRFK1996153-batch-26112010.log
I got the following error:
> Cannot determine byte order for SU format. > Cannot determine byte order for SEGY format. > Cannot determine byte order for PASSCAL SEGY format.
> ----WARNING--- Loading signal ...---- > Unknown format for /data2/NORSAR/noise/GEOPSY/summer96/doy153/HRFK1996153-batch-26112010.log
> geopsy: no signal available, check options -file, -db or -group, see -h for help
However, my data are in SAC-format (neither SU nor SEGY), the data base and group are both readable and the parameter file works fine when using the GUI. Still, geopsy tried to interpret the log file as a signal file.
The reason is probably a syntax change in geopsy - the correct command line call would be
geopsy -db /data2/NORSAR/noise/sac/Summer96.gpy -- -tool geopsyarray -slot 1 -group doy153 -param HRFK1996153-batch-26112010.log
(Note the "--" before all options related to the tool).
