i try to get the newest development version of Geopsy. I followed step by step the instructions from the wiki (http://www.geopsy.org/wiki/index.php/Devel:Installation). When i start downloading the packages ('dpsubdo dpcheckout devel') the first packages are downloaded normally and when i comes to dinver/dist2loc the following error occurs:
######################### dinver/dist2loc #########################
Cloning into 'dist2loc'...
fatal: The remote end hung up unexpectedly
An error occured and there were unfinished tasks
To finish this task, please launch the same task again
I work on a Ubuntu 12.04. The normal download package worked at once.
Thank you for your help.
Error while getting devel branch
Re: Error while getting devel branch
You have to properly define the list of project to install in admin/project.default
dist2loc is a a "private" project in immature state and probably close to dead. Its git repository is not open to public access.
Removing the following line will probably solve your problem:
source admin/projects.private
