Problem exporting SEG2 file format
gschwepp
Post by gschwepp »
I have got some files of the SEG-2 format. I'd like to alter some trace information and then export the files again and keep the file format, because I use some other programs to process the data.
After exporting the files they are corrupt and I cannot open it with any program except Geopsy. So it seems to be an error in the export routine.
I used the Geopsy 2.4.4 (geopsypack57-item-src-2.4.4) on a Ubuntu 12.04 64bit computer.
I just try to install the current development version.
Thank you for your help.
Re: Problem exporting SEG2 file format
Which program are you using for importing the corrupted SEG-2 files? Is it a commercial software? To seek for the problem I must run several tests here.
