gpsh
jkh803
gpsh
Post by jkh803 »
Hi admin,
When I use the command as follow,
gpsh < Test.txt  | figue -c -m sh.mkup
a mistake shows, "gpsh: negative or null value for Qp at layer 0".
I don't know what had happened. Could you help me?
Test.txt
a model files about two layers over a half-space
(319 Bytes) Downloaded 5354 times
Re: gpsh
Your file does not contain any information about attenuation values (Qp and Qs).
You can add them for each layer in your file as explained in help (gpsh -h) or globally with options Qp and Qs.
