ellipticity curve
aseman
ellipticity curve
Post by aseman »
Hi
I want the relation which is used for compute the ellipticity curve?
thanks
Re: ellipticity curve
Everything implemented in gpell is documented in my phd thesis available at http://marc.geopsy.org/publications.html, and precisely at http://marc.geopsy.org/thesis/node61.html.
aseman
Post by aseman »
does Gpell work in windows? is there any tutorial about this?
Pedro Freire
Post by Pedro Freire »
Hello ,
I was also looking for the same information, the previous links are not working.
I am currently having a problem with gpell, when I enter a document with many combinations with the structure below:
3
3 280 163 1800
8 300 211 1800
0 750 521 2200
3
3 330 163 1800
8 300 211 1800
0 750 521 2200
Eventually, it gives the following error : "Error computing ellipticity curve (eventually increase verbosity to debug)".
I am not being able to fix this problem.
All the layers inserted respect the rule: vp/vs < 10 e vp/vs > 1.41.
Is there a maximum nº of inputs?
Any help would be very very appreciated.
Thank you very much,
Pedro Freire
