Build Array
eshabani
Build Array
Post by eshabani »
For a circular array with 10 stations (one in the center) for any radius the theoretical response is the same and there is not a good resolution between aliased peaks. dose this have effect on the results?
[PNG and JPG files can not be attached!!]
theoritcal_response.pdf
(81.3 KiB) Downloaded 3261 times
In fact, for this geometry, the automatic definition of the aliasing limit is not working correctly. This is one reason for keeping this process relatively manual. If you have a high level of the theoretical response between kmin/2 and kmax, there more chances to observe aliasing than a case were the curve is almost flat in this range. I would suggest to take kmax around 0.4.
[that's strange that you cannot upload PNG file, I did it for other post last week, I'll check if there is no user restrictions.]
I've just check the extension control for this forum... the reason might be that you tried with capital letters in the file names.
