Reliable Peak
laleh
Reliable Peak
Post by laleh »
when using the H/V method in Geopsy, is the selected peak frequency reliable based on SESAME guideline criteria? or we have to check those criteria ourselves to select a reliable peak? it seems that the amplitude (H/V value) of a reliable peak should be more than 2, which is not the case in the data I have (mostly around 1.3).
Thank you.
Re: Reliable Peak
No the criteria listed in SESAME are not checked within geopsy.
