Geopsy (3.3.3) doesn't save the *.hv file
Hi Marc, I downloaded today the 3.3.3 release and unfortunately not even this one can save * .hv files.
I was convinced, after your assurances, that this function was fixed, but I see that it is not so. Too bad, I hope you can solve this problem which is very important otherwise all relaeses after 2.9. they cannot be used in Windows environment.
Re: Geopsy (3.3.3) doesn't save the *.hv file
I've just tested it again under Linux with 3.3.4-preview, and it works fine. I will check it tomorrow under Windows and with 3.3.3.
