I'm trying to use geopsy-hv (version 3.4.0 preview) specifying, with the -load-windows option,
a file containing the window to be used; the program returns this message:
----WARNING--- Loading ASCII Columns----
The number of columns is not constant (5 instead of 4), skipped from line 2.
Check number of samples in file '/home/user/prove/hv-et-al/evolution/prova_wins/wins.txt'.
-----INFO----- Loading ASCII Columns----
The ASCII format without header imply that you fill in the correct information yourself in a table.
Choose menu "view/new table" and change the SamplingPeriod (or SamplingFrequency) to allow correct plotting in a graphic
geopsy-hv: Loading /home/user/prove/hv-et-al/evolution/prova_wins/xE...
geopsy-hv: Loading /home/user/prove/hv-et-al/evolution/prova_wins/xN...
geopsy-hv: Loading /home/user/prove/hv-et-al/evolution/prova_wins/xZ...
geopsy-hv: Selected groups:
Option '-load-windows' requires an argument, see -help for details.
I think it interprets the windows file as a data file; I also tried to change the order of the arguments on the command line, but the result doesn't change.
Maybe I am doing something wrong in the way of composing the command? Here is an example of what I try to run:
geopsy-hv -load-windows <windows_file> -param <param_file> -o <output_dir> <data files>
geopsy-hv -load-windows option
Re: geopsy-hv -load-windows option
I'm experiencing the same problem with version 3.4.1.
What could I try?
What could I try?
