Editing header
Lessandro_Sadala
Editing header
Post by Lessandro_Sadala »
Hello, does anyone know how to change or force change the file number value in the data header?
Re: Editing header
Hi Lessandro,
This is not possible inside the GUI, FileNumber is the index of the file which contain the signal in the list of files currently imported in the database. If you want to re-order the files, either start from a new database and change the order of importing files, or untar the gpy file and edit contents.xml. There you could re-order the files. You will see that FileNumber is not a stored property of signals or files.
But why would you like to change this index?
