Setting anti trigger parameters from command line
gaetano.riccio
Post by gaetano.riccio »
I'm trying to use geopsy from the command line (geopsy-hv) including setting the anti trigger,
but I don't know how to set STA, LTA, etc. in the parameters file; I tried to launch geopsy with a graphical interface, use the antitrigger and save the parameters file,
but those relating to the antitrigger do not appear in it.
How can I do?
andrea_V
Re: Setting anti trigger parameters from command line
Post by andrea_V »
Good afternoon, I'm new to this forum and new to Geopsy in general.
I have a similar issue described by @gaetano.riccio. I found on this forum that to set up STA, LTA, etc. it is possible to add these lines to the param. file:
ANTI-TRIGGERING_ON_RAW_SIGNAL (y/n)=y
USED_RAW_COMPONENTS=y, y, y
RAW_STA (s)=1
RAW_LTA (s)=30
RAW_MIN_SLTA=0.2
RAW_MAX_SLTA=2.5
However, when I use the command line and a .param file with these options, the program actually do not take into account the antitriggering. Also, in the produced .log file, the resulting parameter ANTI-TRIGGERING_ON_RAW_SIGNAL (y/n) is set to "n" instead of "y".
I'm using the last version for Windows (3.4.2)
I attach here the param. file I'm using.
Can you give me a little support, please?
Have a nice day,
Andrea
params.txt
(2.77 KiB) Downloaded 5453 times
Hi Andrea,
I run your param.txt on test signals with the latest release (3.5.0-preview). It works fine with anti-triggering. Effectively, with 3.4.2, at least under Windows, there are some problems when parsing the parameters. Hopefully, 3.5.0 is nearly ready to be published. It will be available in few days for Windows and Linux.
andrea_V
Post by andrea_V »
Thank you very much for your super fast support and helpful comment. I'm looking forward to trying the new version!
Andrea
andrea_V
Post by andrea_V »
Thank you Marc.
I confirm it works perfectly under version 3.5.
Have a nice week
Andrea
