Problems running Geopsy on windows
mmorarsn
Post by mmorarsn »
I recently installed the latest version of Geopsy for windows, however, I have experienced some problems such as frequent crashes, some options are not enabled (for example “Default array groups: 3C, H, Z). It is not clear to me if it is eventually a problem with the windows version and I should definitely use the Linux one. If I have omitted something or if there is something in Windows that could interfere with the Geopsy operation. Thank you.
Re: Problems running Geopsy on windows
"Default array groups" is gray because the signals in the current viewer do not meet the criteria for splitting into stations: one signal name per coordinate and all components available for all stations. These are the condition I remember. If you think that they are met and it is still gray, I have to check in the code if there are other conditions.
For the crashes under Windows, I've no advice. Everything is developed under Linux and tested under Linux. Very basic tests are made under Windows.
