Came across creating xy plots with dates using figue but doesn't seem to point to the proper absolute time reference. In my file I have x in the format yyyyMMddhhmmssz (as per -h) and I use the starting time as input to the command -x-abs-time-ref. It is read and plotted in figue but absolute time is offset. That said, could you please advise what the reference should be or if this is a bug? Thanks as always!
File is attached Test.txt
figue reading dates for an x y plot
- Test.txt
- (61.58 KiB) Downloaded 4965 times
Re: figue reading dates for an x y plot
Hi Leandro,
figue reads time as a number of seconds since a reference time specified with option '-x-abs-time-ref'. Hence to plot your data the command line should be:
gptime is a tool provided with geopsypack that can convert time formats ('-i'=input format, '-o'=output format). '-c 1' is to modify only the first column. time_t returns the number of seconds since 1970-01-01.
Any other time reference is possible. A reference date closer to the actual times ensures a better precisions (if nanoseconds are required).
cat Test.txt | gptime -i "yyyyMMddhhmmss" -o time_t -c 1 | figue -c -x-abs-time-ref 19700101000000Code: Select all
$ head -n 3 Test.txt
20240503040335 -3.94 1
20240503041359 -3.94 1
20240503042423 -4.19 1
$ head -n 3 Test.txt | gptime -i "yyyyMMddhhmmss" -o time_t -c 1
1714709015.000000 -3.94 1
1714709639.000000 -3.94 1
1714710263.000000 -4.19 1
cat Test.txt | gptime -i "yyyyMMddhhmmss" -o "seconds since 20240101" -c 1 | figue -c -x-abs-time-ref 20240101000000
