figue reading dates for an x y plot
Posted: Sun Aug 17, 2025 1:07 pm
Came across creating xy plots with dates using figue but doesn't seem to point to the proper absolute time reference. In my file I have x in the format yyyyMMddhhmmssz (as per -h) and I use the starting time as input to the command -x-abs-time-ref. It is read and plotted in figue but absolute time is offset. That said, could you please advise what the reference should be or if this is a bug? Thanks as always!
File is attached Test.txt
