save results HV
geode
save results HV
Post by geode »
in new version of geopsy I don't see the way to export the HV spectra in a file.hv There in not "save result as".
do you have suggestions?
thank
You can find the "Save results" and "Load results" in menu "Tools" from result sheet (not the general geopsy menu "Tools").
You can also automatically save .hv or .spec file by specifying a file path in HV or Spectrum toolbox under tab "Output".
hflores
Re: save results HV
Post by hflores »
Hello, I'm interested on the HVfta as I've been working with theoretical ellipticity. However I haven't been able to save the *.max needed in max2curve.
I'm working undser windows7 with geopsy 2.7.4 (geopsypack 2.4.2)
I have also registered myself to download the HVfta plugin but probably I have to wait sometime for the password?
Thank you.
