Hello i have a problem loading an ascii file (*.trc) with 3 component N-S, E-W, U-D, this is the error message:
"Tromino ascii file: error reading header"
i tried to modify the header in every way!!
Suggestion?
thanx.
problem loading tromino ascii file (.trc)
Re: problem loading tromino ascii file (.trc)
I would like to import tromino trace into geopsy software, but till now, I can't do it? I can I do to perform analysis trace recordered by TROMINO with geopsy?
Marcello
Marcello
Did you try to export them to sac or another format readable by Geopsy using Grilla?
I had the same problem, and I followed your instruction, then I get a .saf (doing export from grilla). But when I try to load this file on geopsy I have an error message saying: "Loading ASCII values from file.saf: Reaching the end of file at sample 0, missing sample". Even if in the N sample column of the table shows 290406. So, I don't know what to do.
