problem loading tromino ascii file (.trc)
gonzo80
Post by gonzo80 »
Hello i have a problem loading an ascii file (*.trc) with 3 component N-S, E-W, U-D, this is the error message:
"Tromino ascii file: error reading header"
i tried to modify the header in every way!!
Suggestion?
thanx.
After discussions with Tromino developers, Tromino ascii is definitively not a standard format. Users can customize it. This format has been removed from the list of readable formats. Apparently, Tromino software is providing export to sac or other common formats, readable by geopsy.
mermia
Re: problem loading tromino ascii file (.trc)
Post by mermia »
I would like to import tromino trace into geopsy software, but till now, I can't do it? I can I do to perform analysis trace recordered by TROMINO with geopsy?
Marcello
Did you try to export them to sac or another format readable by Geopsy using Grilla?
melou
Post by melou »
I had the same problem, and I followed your instruction, then I get a .saf (doing export from grilla). But when I try to load this file on geopsy I have an error message saying: "Loading ASCII values from file.saf: Reaching the end of file at sample 0, missing sample". Even if in the N sample column of the table shows 290406. So, I don't know what to do.
